Ir para o conteúdo principal
Motorola released the Droid Turbo 2 in late October 2015. Model number XT1585.
Why is my battery draining really fast?
After I fully charge it, the battery seems to not last as long as it used to. I don’t watch a lot of videos or do any gaming. Is my battery just broken or faulty?
Esta é uma boa pergunta?
Pontuação 4
Adicionar um comentário
2 respostas
Solução escolhida
To help save the battery life, try closing any running background applications in the running apps menu. You can also turn off or reduce your use of Wifi, GPS, and Bluetooth.
Also, the screen’s brightness can drain the battery life too, so try dimming the brightness.
If these suggestions do not work, you may need to replace the battery. You can check out this troubleshooting page for more help.
Esta resposta foi útil?
Pontuação 2
3 comentários:
You can force stop the apps running in background that you never use such as Kindle or Amazon....,.
por
Mine will shows fully charged, but will then shut off between 30 and 45%. Sometimes as high as 50... It only lasts for a a couple hours of use!
por
My gf's phone WAS doing the exact same thing. Ended up having to replace the battery using the guide on here.
Doesn't help that Motorola forces that asinine always on screen "feature."
por
I don’t think it has anything to do with apps running in the background, brightness etc. This is an internal issue. My husband charged his phone to 100%, turned it off before leaving for work and when he went to turn it on at lunchtime, it was at 4%. I strongly believe this is a factory defect and it should be addressed by the manufacturer. This issue was not resolved yet.
Pontuação 0
1 comentário:
Did you ever get answer about the battery? Mine is doing the same thing. Bad thing is I just bought it off of marketplace and can't get a refund. What should I do?
por
Adicionar a sua resposta
Chisi Amanda Xiong será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 56
Ao todo: 8,725
