Ir para o conteúdo principal
Released in 2011, the Asus K53E-BBR7 laptop features an internal 640GB HDD with a speed of 5400 RPM, and a 2nd generation Intel Core i3 processor.
Why won’t my laptop charge when I have it plugged in?
I noticed that when I connect my power adaptor to my laptop, it won’t charge. I’ve noticed that there is heat coming from the connector head of the power adaptor, but it still isn’t charging when it is connected to my laptop.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If you are noticing that your power adapter is functioning but your laptop is failing to charge, there may be an issue with your laptop’s charging port. The charging port often fails on this laptop due to excessive use. Refer to the Asus K53E-BBR7 troubleshooting page for additional information at Asus K53E-BBR7 Troubleshooting.
Esta resposta foi útil?
Pontuação 1
2 comentários:
yeah and check if the battery is given reacharge by the mainbord
por
but most laptops have a split funkion that reacharges the battery and the cable power the pc itself and leave the battery to charge alone if it cant even turn on the adapter may not have power at all
por
Adicionar a sua resposta
Christina Nelson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 204
