Ir para o conteúdo principal
O Dell Vostro é um modelo de uma linha de notebooks criados pela Dell para uso empresarial. O Vostro 1500 foi lançado em 2007.
Why is my screen so dim?
I'm confused as to why my screen is dim. How can I make it brighter?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Sorry for having to ask, but have you tried turning the software brightness up to max? Is it an issue with the panel itself?
por
Adicionar um comentário
4 respostas
Pergunta mais útil
To increase the brightness of the screen hold down the "Fn" key and press the up arrow key. To lower the brightness do the same but instead of the up arrow key press the down arrow key.
Esta resposta foi útil?
Pontuação 1
1 comentário:
I second this.
Hold "Fn" key and use the Up Arrow and Down Arrow keys to adjust the brightness. If this doesn't work, then look into possible problems with the LCD.
por
If software is not the issue, you may have to replace the entire screen assembly. Don't fret yet, though, as there are some things you can try before resorting to the 'Nuclear Option'.
Try cleaning the contacts between the display assembly and the motherboard. Laptops are prone to collecting massive amounts of gunk and dust over time, and swabbing the connection with liberal alcohol may fix it. Remember to dry all components before reassembling the laptop.
If that doesn't work, there are other possible causes of failure. This includes power supply issues, motherboard issues, and graphics manager issues. If your computer supports it, you may be able to run an ePSA. This boots your computer into a mode where it systematically runs onboard tools to determine what may be broken. Different computers has different ways to access this mode, but you might be able to access it through booting into the BIOS mode.
Pontuação 0
Replace screen inverter
Pontuação 0
I had the same problem and i replace the Screen. But iam sure this is a screen inverter problem, you should find an 100% compatible inverter for your screen model or buy new screen that include the inverter.
Pontuação -1
Adicionar a sua resposta
Timothy Letourneau será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 13
Ao todo: 2,263
