Ir para o conteúdo principal
Where to get rubber feet?
Hello all!
I have a little problem of I sent in my laptop (asus zenbook pro UX501) to get the wifi card changed because it was under warranty still and I was a little hesitant to do it myself as in order to open the laptop as I would need to take of the back rubber feet and I was afraid they would not stick very well after... well apparently I should have done it as when I got the laptop back it was, you guessed it, missing the back rubber feet now asus says I need to send it back to have the feet replaced by "professional technicians" (BS) and will need to pay shipping there (about $30)
Does anyone know where I can get some ( preferably authentic) back rubber feet with adhesive? I don't like the idea of when all is said and done spending a total of $60 (original RMA shipping included) and 2-3 months of it being gone (RMA took about 1.5 months plus shipping, then 3 weeks minimum for the feet)
Esta é uma boa pergunta?
Pontuação 1
1 comentário
SOLVED for cheap. The link for Amazon below is for 4 feet that fit perfectly. You will have to take an exacto knife or something to core out a little hole in the bottom of the foot for the little knub on the laptop, but it was simple. For reference in case the link stops working, these rubber feet are 19mm x 19mm x 4.5mm high. Any feet this size should work, but again you'll have to core out a little of the foot for the little plastic piece that sticks up. Enjoy!
https://www.amazon.com/gp/aw/d/B01BT9761...
por
Adicionar um comentário
2 respostas
Solução escolhida
Hi,
Here is a link to the parts for a UX501
http://www.asusparts.eu/en/partfinder/As...)
Enter ux501 in search model box, click Search, then click on Asus Notebook N series N501jw (ux501jw, G501jw) link.
When new window opens, scroll down to Miscellaneous, click to expand, scroll down to find Rubber foot parts for the two models
Hopefully one is for your model.
Esta resposta foi útil?
Pontuação 5
7 comentários:
So then I'm assuming that the n501jw feet are the same as the ux501jw feet or do you know?
por
Yeah I forgot that shop. They are very helpful, I found a brezel to my Bluray drive there.
Yes there are a few spare parts that fit different models my BD brezel was for a laptop also starting with N
por
Hi, I have no idea. I have only used them once before to get parts for an entirely different laptop. Perhaps the easiest and quickest way to get an answer to your question is to contact them.
http://www.asusparts.eu/en/Home/ContactU...
por
Also do you know why there are 4 different model numbers on said feet?
por
Hi,There are two model laptops ux501jx and g501jw they show parts for Rubber Foot Rear Right x 2 and Rubber Foot Rear Left x 2 therefore you have four different model numbers. I don't know which part belongs to which model . You might assume that since they list the ux501jw first (at the top of the page) and the G501jw second it might mean the the first Rubber Foot Rear Right part number ifs for the 1st model and the second listing is for the second model., but that is only a guess. Contact them to find out for sure.
por
Exibir mais 2 comentários
I have not found the ones for UX501 one but if you know the measurements of your rubber feet some might be the same .
http://www.ebay.com/bhp/laptop-rubber-fe...
http://www.ebay.com/sch/i.html?_from=R40...
Hope I could help you a bit.
Pontuação 0
1 comentário:
Thanks for the effort but all of these are for the zenbook line not the zenbook pro witch is ware I am haveing problems the back feet on the zenbook pro are... raised I guess you could say they are not the same as the front feet...
por
Adicionar a sua resposta
ETHREAL1 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 28
Duração total: 12,352
