How can I repair genius satelite 2.1 SW - S2.1 900 ...
Hello the problem with how can i repair genius satelite 2.1 SW - S2.1 900 is in the din connector 9 pin, the cable broke and I do not know in which order the cables I have bought a replacement plug to weld it but I do not know Color order anyone can help me? Attached image of system 2.1 and connector
The colors of the cables are
Red
green
yellow
blue
White
black
orange
Brown
And a ground wire that in the metal part of the connector
http://www.geniusnet.com/Genius/wSite/pu...
Esta é uma boa pergunta?
3 comentários
Hello
I only got loose dres and a new Conector, but I can not continue without colors for the PINs connection. Maybe someone has the connection scheme with the colors?
po.mi@gmx.at
por po.mi
I have the same problem
Have you been able to solve it?
por Nico
I have no time in the moment, but if you disassemble it, you can find the connections logical. There are the wires to 2 boxes and 2 controllers. I'll do it later. Then I write it down.
por po.mi
