Ir para o conteúdo principal
Why does my coffee taste bad?
The coffee I brewed in my Keurig has a bad taste to it and I noticed some small beans in the cup as well. I've been using this model for years now and recently I've noticed an unusual taste to the coffee.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
If your coffee has a metallic taste to it or has coffee grounds in the cups, then the Keurig will need to be cleaned. To clean the brewer, fill the water tank on the left side with a mixture of white vinegar and water. Now keep making hot water with the Keurig so that the mixture keeps going through the system. This should get rid of any build up inside it.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
michelinval será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 16
Últimos 30 dias: 44
Ao todo: 23,344
