Ir para o conteúdo principal
Known as the Canon EOS Rebel XTi in North America, the XTi is a budget Canon DSLR released in 2006 with a 10.1 MP sensor. Also known as the EOS 400D and the EOS Kiss Digital X.
LCD DISPLAY CLEANING assistance
Dear friend,
The LCD display at the back has white spots due to mold. This camare has hardly been used. Mold has formed in the inside of the lcd display.
What can I do to resume to its original state?. The camera works perfectly well it is only this inconvenience of the display.
Thank you for your kind assistance
Hans
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Just clarifying. Has the mould formed on the back of the LCD window glass or on the inside of the LCD display itself?
If it is on the back of the LCD window glass then here is a link to the Ifixit guide on how to remove the back casing of your camera. Hopefully by using this guide you will be able to gain access to the window glass to clean it.
Canon EOS Rebel XTi Back Cover Replacement
If the mould is on the window glass and cleaning does not remove it for some reason or other then here is a link for a replacement part.
http://www.ebay.com/itm/Canon-EOS-400D-R...
If the mould turns out to be in the LCD itself, which would be unusual as it is supposed to be a sealed unit, then the only thing to do then is to replace the LCD unit.
Here is a link to just one supplier of the part. This is just shown to give you an idea of the price of the unit. Search online if you need or want to get the part.
http://www.uscamera.com/ch9-1098.htm
Hopefully this is of some help.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
hans rajiah será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Ao todo: 786
