Ir para o conteúdo principal
How do manufacture re set my camera
How do I reset my g
Digital camera cause when I turn it on it tells me to power off then power back on then when I do it says the same thing all over again it want let me take pictures please help me
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
What is the make and model number of the camera?
Can you easily remove the battery from the camera?
If so, remove the battery, then press and hold the power button for 10 seconds, release the power button and replace the battery and turn it on and see if it works OK
Esta resposta foi útil?
Pontuação 2
3 comentários:
i tried what u said it didnt work its saying macro invalid
por
seriel # is 6890324 an modol # is DSC-W120
por
Hi, OK one more try. As the error seems to be different now changing from message saying power off then power on to macro invalid, perhaps the reset time wasn't long enough. So once again remove the battery, press and hold the power button for 20 seconds this time, release the power button, insert the battery and see if it is working now or if the message has changed.
Sony's recommended reset procedure is to just remove the battery for 15 seconds then replace it and try.
If the first suggestion in this comment still doesn't fix the problem try the second and see it it works.
por
Adicionar a sua resposta
sarahsands será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 4
Duração total: 59
