Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemaSamsung Television. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Samsung Television.
Smashed Samsung LCD screen help
My 40' Samsung TV (model: LEA40A457C1D) screen has been broken/cracked.
There is no picture but just a black background with cracks and blue, red, green,etc lines with a bit of white. Is there anything I can do to replace the screen or glass or is it not worth it?
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
@bwilson90 that panel ( if it is even available) will most likely cost you more than a new TV. You can of course always try to find a TV of your model that has other issues and harvest the panel from that. If you do want to look for it, you will need to do so by the make and the model number of the panel itself. On the back of the panel should be a sticker that will tell you who makes it and what model it is.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Ben Wilson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 114
