Ir para o conteúdo principal
A series of Gigabit NAS desktop drives of 1TB, 2TB, and 3TB varieties, made by WD in 2010.
My western digital not appear in file manager
Western Digital my book was healthy until I connected it to the PlayStation 4 After , the device turns on the lights But not appear in the Windows file manager and disk management (in manage) but in "Device Manager" appears and i saw the icon for safley remove in taskbar . I was Tested with another cable, as well as with another system but it dosnt work
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Hi, Can you 'see' it when you connect it back onto the PS4?
por
Adicionar um comentário
1 resposta
Did you look for it in your network Bottom section of File Manger - Labelled Network. My Network
Drive only shows up in the network since mine only connects to a network and has no USB connector. When you connected it to the PlayStation 4 did it in any way format or configure the drive to work with the PS4. If it did then it might of - formatted that Drive and now it will only work with the PS4. I would go to the WD Website to see if there is any Recovery software for your WD Live Book.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
mohamadhajari será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 7
Ao todo: 653
