How can I check the cause of backlash in the rear axle?
1800 E Sports Coupe
There is a transmission "snatch" (jerking) when driving slowly, usually in the higher gear ratios, accompanied by a knock when decelarating. It normally happens during gear changing, but disappears when driving normally in top gear
I have checked the driveline and all propshaft bolts are tight and there is no "play" in any of the universal joints. Transmission rubber mountings are sound.
With the wheels on the ground, I can detect about 1/4 inch of free-play when I turn the propshaft in either direction. I know that some movement is normal. but I don't know how much constitutes wear in the rear axle.
Has anyone experienced this with their Volvo 1800 E or ES models?
Esta é uma boa pergunta?
2 comentários
Derek what year is your P1800 ES? Volvo used different rearends during model change
por oldturkey03
Derick is there any leakage at the pinion gear . Will the pinion gear move forward at all if pried with a pry bar
por Jimfixer
