Ir para o conteúdo principal
Released in March 2011, the Fujifilm FinePix XP20 is an easy-to-use, rugged and waterproof, point-and-shoot, 14 MP digital camera. Available in blue, black, green, silver, or orange.
Why did my menu button stop working?
I dropped my camera and my menu button stopped working
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
Odd messages, latch not closed, then memory error, then will not shut off or take picture
por
Adicionar um comentário
1 resposta
The Fujifilm XP20 is supposed to withstand most impact forces from a height from around 5 ft. However, if the camera was dropped into a dirty area, the buttons may have gotten filled with dirt or dust. If this is the case, then you may need to clean out the buttons using a compressed air can, or a small brush. Water, or rubbing alcohol could work on this camera was well, since it is waterproof. If this solution does not work, then there may be a problem with circuit or motherboard of the camera. This could be self-replaced with time and knowledge of the camera, or by taking it to the nearest tech store. For more information on troubleshooting, please view our Troubleshoot page.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Stephen Harden será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 11
Ao todo: 439
