Ir para o conteúdo principal
2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Perguntas Visualizar todos
Replace SSD with models from 2015.
Hi
Can I replace original M.2 SSD with something like SSD 960 EVO NVMe M.2 1TB ?
Will it work at all? And can it support the speed of storage?
original is 500 MB/s write and reed, and on link is 1900 write and 3200 read MB/s.
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Sadly, no.
Apple uses a different physical interface from the M.2 SSD products you can buy from Samsung. While many of the SSD's Apple uses are made by Samsung they are OEM.
There is a 3rd party that does make a compatible SSD OWC - SSD Upgrades for MacBook Pro with Retina Display 13" & 15" Late 2013, 2014, & 2015. Or, you'll need to find a used unit on eBay which can be a bit of a gamble.
Esta resposta foi útil?
Pontuação 2
Yes you can with this adapter: http://eshop.sintech.cn/ngff-m2-pcie-ssd...
but only Linux or Windows installer will detect the drive. MacOS doesn't support NVMe for OS booting at the moment.. maybe in future.
Pontuação 1
2 comentários:
So apparently the MacOS High Sierra will support nvme ssd out of the box. :)
www.insanelymac.com/forum/topic/324306-nvme-native-support-in-1013/
por
Good find!
mmm... I'll need to check it out once I get the needed parts. Remember High Sierra is in Beta so we'll need to wait till the full release to be sure they don't close the door on us ;-}
por
Adicionar a sua resposta
Volodymyr B será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 257
