Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Is my battery the problem or my lightning connected port
I plug my iPhone 5s in to charge and it responds saying it's charging then it comes on and doesn't get past 1%? I tryed 2 other chargers aswell and that's no use? So I was wondering if I need to replace the battery or the lightning port connecter? Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Solução escolhida
Or just try another charging port dock (charger port ribbon cable / flex assembly) first then another battery.
Esta resposta foi útil?
Pontuação 3
Well the first thing you want to do is some troubleshooting on the iPhone to see why it's not charging. The phone would need to be opened and with a muti meter test the charging port, then test the battery to make sure the correct amps are going to the device. If the battery and charging port are good then it may be a U2 IC chip which is on the motherboard and would require soldering to replace the chip.
Pontuação 1
Neither, could be board problem.
It could be the charging IC Q4, especially when USB data works, replaced battery and still not charging.
Pontuação 1
Adicionar a sua resposta
Theo Burns será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 66
