? cooling fan relay
where is the cooling fan relay switch in a 2012 jeep wrangler ?
Esta é uma boa pergunta?
@agent86 ,Bob, the electric cooling fan HI and LOW relays are located in the power distribution center (PDC) under the hood/engine compartment. Fuse and relay layout label affixed to the inside surface of the PDC cover for cooling fan relay identification and location. Also check out the attached link, diagnosing cooling fan problems, good article fuses,relays, fan motor,etc. Good luck.
Esta resposta foi útil?
Not so for the 2010 JKU 3.8 SAHARA RHD
Últimas 24 horas: 0
Últimos 7 dias: 10
Últimos 30 dias: 58
Ao todo: 24,987
1 comentário
There are two relays tucked together in the passenger side fender wall in the engine bay. What do they function?
por Jack Mahanyele
