Ir para o conteúdo principal
The Magic Bullet NutriBullet Pro 900 Watt Blender is a small-sized blender used for blending up veggies and fruits.
Why is my blender cap leaking?
When blending the blender bottle leaks out of the seal.
Esta é uma boa pergunta?
Pontuação 2
3 comentários
Mine is also leaking but its because the blade is loose and liquid goes in where the blade post is.
por
My ninja is new. I am filling it only 1/2 way. Still I have leaks into the base. I am very unhappy with this appliance.
por
it is the worst appliance will never buy this stuff ever again and csr is no help either
por
Adicionar um comentário
1 resposta
Pergunta mais útil
The rubber gasket inside the cap could have a break or a crack. It can be replaced if you follow this link for rubber gasket replacement.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Brett Crews será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 7,694
