Why is my Motorola XOOM 2 ME running slow?
My Motorola XOOM 2 Media Edition is running really slow. The device lags when I try to complete simple task and is often unresponsive. Someone help!
Esta é uma boa pergunta?
Hello Taylor, there are multiple reasons why your device may be running slow. They most common solution is to soft reset the device. Simply restart the device. If you do not want to power down your XOOM you can try closing out of any open apps. If your device is low on memory you can look at the repair guide to expand the memory.
Esta resposta foi útil?
Already did it
Hi @Susy Leonard,
Try the following to see if either of them resolves the problem:
i). Wipe the cache partition and check if the tablet works OK.
ii). Try starting the tablet in safe mode and check if the tablet works OK. If it does then a downloaded app is the cause of the problem. You will have to uninstall each downloaded app, one by one and test the tablet in normal mode between each uninstall to see if it works OK. When it does then the last downloaded app that was uninstalled was the culprit. A downloaded app is one that you downloaded and installed in the tablet and didn’t come pre-installed with the tablet.
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 13
Duração total: 730
1 comentário
I see no question OK?
por Susy Leonard
