@jthawthorne , John, You want to remove a stuck on brake drum correct! When they are stubborn like this,remove cotter key and castle nut, make sure park brake is fully off, some times there will be a ridge on the drum from wear and you must locate the adjuster and turn adjuster star wheel to release/decrease brake expansion allowing more play for drum to slip over worn ridge on drum. Spray spline liberally with a good penatrent oil. Hit drum with heavy hammer hard multiple times on the face edge of drum, this will normally send a good vibration to release drum from axle. Still not releasing the next step would be to heat drum at hub till almost red hot and then hammer off. If it is still not budging, time to bite the bullet. Get out the angle grinder with cutting wheel, cut 2 slot in the drums hub perpendicular/across to each other, cut almost to the axle spline(stop before damaging axle), then with a heavy hammer and cold chisel, place chisel in cut slot and hit solidly rotate to other cut slot in drum hub and repeat. This will spread/crack the hub from axle spline after a few tries, allow hub to come off. Now of course that means time for new hub $40-$50. Anti seize spline before putting drum back on. Good luck.
Check for retaining clip/c clip and remove. Check the attached link for instruction on hub/axle removal. Check the attached links,instruction and guides, Good luck.
http://www.buggiesgonewild.com/electric-...
https://www.manualslib.com/manual/836546...
3 comentários
@jthawthorne what model EZGO do you have?
por oldturkey03
Do away with the torch and buying a puller! Here is what I did. Take off the wheel and the castle nut and spray with PB Blaster. Let soak 15-30 minutes or so. Do not put the castle nut back on, but put the wheel and lugs back on. With the cart still lifted on the one side, beat the back side of the tire with a rubber mallet several times and it should come loose.
por toolteam4x4
I tried everything mentioned here - a few different penetrating oils (including PB Blaster), a hub puller with center push screw, a hub puller with a slide hammer, a torch, a regular hammer, putting the wheel back on and beating it. Didn't get even a tiny wiggle. Finally took the angle grinder to it and made mincemeat of the whole thing. It did come off, but I nicked up the axle in the process, so I get to replace that, too.
Regarding old Turkey's fix, I think it's misleading to say the least. According to every diagram I've seen, the hub and the drum are part of the same piece - in that regard, no, you cannot remove the hub without removing the drum, but it's because they're the same thing. And it's not the brake drum that's held in place by 4 bolts, it's the backing plate - which is also the piece that holds the brake pads. The diagram included is unfortunate, since it cuts off the name of all the relevant pieces. I've seen elsewhere that #102 is the hub/drum, and #89 is the backing plate.
por Bob
