Ir para o conteúdo principal
The Garmin Dezl 760LMT is a GPS manufactured in 2012 by Garmin. It has a 7” screen, and is able to store and utilize maps from an SD card or an assortment of pre-loaded maps of the United States and Canada.
8 Perguntas Visualizar todos
Why does my screen stay black when I turn on my GPS?
When I try to turn on my GPS, nothing shows up on the screen. I can't seem to figure out if I'm doing something wrong or if there is something wrong with my GPS. Any help would be great.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
There are a few possible causes for this problem. It could be an issue with the battery, the charging cable, or the screen itself. There’s unfortunately not a great way to tell which it is without checking it all. However, there’s a great process to follow over at the Troubleshooting Page! Hopefully this should be able to get the issue sorted out.
Esta resposta foi útil?
Pontuação 4
2 comentários:
I have a new Striker 4 77/200kHz
All systems worked while out boating. At the end of the day I turned on the system sand got a black screen being able to see only a very very faint home screen. What is the problem? Striker 4 77/200 kHz
por
If the screen is faint then that means that your back light has gone out. The new electronic screens other than LED or OLED need a light behind them to brighten the image. The cells do not emit light hence the need for a backlight. Google led technology and it will tell you everything you need to know but basically you need to have the backlight replaced.
por
Adicionar a sua resposta
Shane Luttmann será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 21
Últimos 30 dias: 89
Duração total: 19,071
