Ir para o conteúdo principal
Um smartphone Android identificável pelo número de modelo d2004 ou d2005, lançado em março de 2014.
two way communication problems
If i make a call, i cannot hear my phone making the call, but the call does go through. The person on the other side can hear me, but i cannot hear that person. What is the problem? Please adviseme on my EMail at scholtzflip@gmail.com
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi,
Have you checked the volume level when you are making a call?
Have you tried using the loudspeaker option when making a call?
If these are both OK then perhaps the receiver in the phone is either faulty or has become disconnected from the systemboard.
If you do not wish to use the loudspeaker option try using the earphones with the microphone attachment and if it works OK as well use this until the phone is repaired.
If you still cannot hear after trying all 3 options listed above then there is a problem with the voice reception circuitry in the phone.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Philippus será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 18
Ao todo: 320
