Ir para o conteúdo principal
A linha de laptops MacBook Pro da Apple foi concebida para usuários avançados e profissionais. Atualmente, a linha MacBook Pro inclui as variantes de 13, 14, 15, 16 e 17 polegadas, com revisões maiores definidas pelos designs Pré-monobloco (original), monobloco, tela Retina, Touch Bar e SOC (system-on-a-chip).
20010 Perguntas Visualizar todos
How to backup Apple Mail email database automatically?
I am a daily soap user of apple mail which is linked to my Gmail account. I suffered from a very sad case where I lost all my emails due to the server crash. Only 70% of my emails were recovered leaving me even more frustrated. Leaving the past behind, I wanted to make arrangements that this never happens again. Now I am looking for a backup solution that can backup my incoming emails on my hard drive, and more importantly that the solution should automatically backup the email as soon as it is received in the mailbox.
Helpful solutions will be really appreciated. Thanks
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Pergunta mais útil
If you want to fiddle with it - I have not done exactly this, but... - maybe you can use "folder actions": Find your Mail folder in your library, ctrl-click the folder and choose Services at the bottom of the popup, and Folder Actions setup.
I remember I found a script at some point, when I needed an FTP program to automatically upload any NEW doument that arrived in a designated folder.
This is similar. You could save your mail folder by having a folder action copy any changes to the mail folder to your cloud Mail copy folder (allow time for email download to finish, eg when checking your mail in the morning or at email rush hour, otherwise you may end up with copies of half arrived emails. Or you could set the folder action to only upload, when your email program is idle or closed. NB: Email attachments go into a different folder in the Library). Or you could backup to a mounted hard drive folder, or USB stick.
It may not be exactly what you had in mind, funtionality wise, but you will get an instantaneous copy.
Good luck with finding and editing a script. It CAN be done.
And if you find or make a functioning script, please let people know here.
Esta resposta foi útil?
Pontuação 2
Best solution is to export your email database, that way your emails also remain safe and secure. Here's the procedure:
Export mailboxes
Select one or more mailboxes, then choose Mailbox > Export Mailbox.
Choose a folder or create a new folder, then click Choose.
Mail exports the mailboxes as .mbox packages. If you previously exported a mailbox, Mail doesn’t overwrite the existing .mbox file; it creates a new .mbox file, such as My Mailbox 3.mbox.
Pontuação 1
You can also view this forum discussion to how to backup Apple Mail emails database
https://discussions.apple.com/thread/805...
Pontuação 0
Adicionar a sua resposta
Phil Bones será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 175
