Ir para o conteúdo principal
The Stream 7 is a compact multi-use tablet produced by Hewlett-Packard and was released in September of 2014.
Is there a way to make my battery last longer?
I've been using the device for a while, and it seems over time that the battery life has been significantly diminished. Is there anyway to help or fix this problem?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Hey Brennan,
Great question! I think we all could use a longer battery life for all our devices! There ARE a few tricks you can try.
- Free up some RAM by closing out of apps when you're not using them
- Turn brightness down whenever possible; the backlight is a major drain of battery life
- Turn off bluetooth and wifi whenever possible
- Limit notifications
If none of these seem to do the trick, it may be time for a new battery. Head over to our battery replacement guide to get started.
Best of luck!
Esta resposta foi útil?
Pontuação 0
3 comentários:
Brennan, did you just post and answer you own question???
por
@lpfaff1 Remember, I told you to watch out for questions like this. Check the OP - student
por
mayer, yes you did,thanks :-{(
por
Hey Brennan,
If none of these seem to do the trick, it may be time for a new battery. Head over to our Battery replacement guide to get started.
Best of luck!
Pontuação 0
Adicionar a sua resposta
Brennan Slater será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 269
