Ir para o conteúdo principal
O Fitbit Zip é um dispositivo rastreador de fitness com clipe da Fitbit, anunciado em setembro de 2012.
Correct time cannot be set on my Fitbit
I don't know how to change the time on my Fitbit Zip
Esta é uma boa pergunta?
Pontuação 197
15 comentários
set time on fitbit
por
I don't know what is my fitbits name and I can't set the time
por
Correct the time on my Fitbit
por
There is not anything visible. Satting in mobile
por
I can't correct the time on my fitbit watch
por
Exibir mais 10 comentários
Adicionar um comentário
4 respostas
Solução escolhida
Hi Marg,
You have to change your settings on Fitbit's website:
-Log in to your fitbit.com dashboard and click the gear icon in the top right corner.
-Click Settings.
-Scroll to the bottom of the Personal Info page and modify your timezone.
-After saving your changes, force sync your tracker: Click the Fitbit Connect icon located near the date and time on your computer. Click Sync Now.
Hope that helps!
Esta resposta foi útil?
Pontuação 55
17 comentários:
I have tried all the suggestions and I still can't get the time right.
por
Is there a video showing step by step how to fix clock
por
How do I change the device my fitbit was originally set up to? I no longer have that computer and I need to reset the time
por
i went to the app on my phone,went to advance settings ,turned of auto time zone ,selected my time zone ,ie Melbourne ,went out of settings to dashboard tap the blaze clock top right corner then tap sync now and all fixed
por
Exibir mais 12 comentários
Hey guys. To fix your time zone:
1. Go to Account -> Advanced Settings
2. Turn off automatic time zone
3. Select random time zone
4. Sync
5. Go back to Account -> Advanced Settings
6. Select your correct time zone
7. Sync
Ta-da!
Pontuação 10
6 comentários:
I don't have the computer I set up my fitbit on. Recently got a new on. How do I sync it to the new one?
por
Frank, you're the King!
por
ok. I'm getting better. where is Sync?
por
My ap is still searching for the Fitbit. It found it, then said to put in the number displayed on my app. I did that and it’s still searching. It’s been 15 min. The Fitbit doesn’t sync to my phone. It hasn’t worked since the first week. So I can’t track anything but the rest still works. So how do I get my time corrected on my Fitbit?
por
I did all that and the time on my fitbit alta hr on my hand is still wrong
por
Exibir mais 1 comentário
Hi All
I went to the app on my phone,went to advance settings ,turned off auto time zone ,selected my time zone ,ie Melbourne ,went out of settings to dashboard tap the blaze clock top right corner then tap sync now and all fixed
Pontuação 3
10 comentários:
I tried this several times, still doesn't work,
por
Same here ... terrible !
por
You have to turn off auto time zone on phone, select a city with your correct time zone, then, on phone, tap the Fitbit icon, then turn on auto time zone and select a city with your time zone.
por
Tried and tried time keeps revert back to Los Angeles given up
por
Go on to your account profile and view personal go into location and make sure it’s on then save it sorted out both my surge and ionic times are correct now
por
Exibir mais 5 comentários
App Settings.
Turn off the Automatic time zone option. Tap Select time zone and choose the correct time zone. Sync your Fitbit device.
Regards,
Will
Pontuação 0
Adicionar a sua resposta
Marg Henschel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 35
Ao todo: 280,130
