Ir para o conteúdo principal
Repair information for printers made by Canon.
My printer shows a fault code B200
I was changing the cartridges on my Canon MG5550. I left the machine for twenty minutes with the print head carrier in the access position. When I returned the display showed fault code B200. Prior to me removing the ink cartridges, the machine was working well.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
@muppet try this first:
1. Turn OFF Power
2. Open the print head bay (as though you were about to change inks)
3. Turn ON power
4. Wait for print carriage to start moving to the left and let it go past half way
5. Before print carriage reaches left hand side (but after going halfway across) shut the cover.
6. Leave the Printer turned on
if that does not work try the suggestions on here.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Mallory Allfree será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 501
