Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
Charging iPhone 4s problem?
My iphone 4s will only charge sometimes. I have to plug it in and out a bunch of times until it finally charges.
but when my phone shuts down and I plug it in once it will charge until it turns on and then the battery is not charging at all once the lock screen loads up?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Solução escolhida
If you haven't already, firstly try another charging cable and / or wall adapter.
Those are all signs of a bad charging port. Replacing it should do the trick.
Where you can buy the part:
iPhone 4S Dock Connector
Guide to replace the part:
iPhone 4S Dock Connector Replacement
Imagem de Replace a dirty, damaged, or corroded dock connector to fix problems with charging, connectivity, and USB recognition.
Produto
$19.99
Esta resposta foi útil?
Pontuação 3
if you're able to check the voltage of the battery would be helpful to know also. It could be the battery either needs a boost or is defective.
Pontuação 0
Adicionar a sua resposta
Steph será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Ao todo: 138
