Ir para o conteúdo principal
Searching or no service
Hi Guys.
OK got a 6 plus thats having a few issues which i'm trying to put right for a client.
She had a screen replacement from a so called reputable shop which in all honesty was a mess 3 times they tried & in the end put a broken screen on & refunded her saying the fault was with the body by the volume controls which where there was damage.
I replaced the screen for her & we tested it here she had full signal & was able to send & receive calls i also attempted to straighten out the damage to the body.
it was all working fine except for no sound from the main speaker on the phone which i said if she could pop back i would take a look at it for her.
Just so i can get this straight in my head the top left of the board the antenna there is the wifi & bluetooth & the GSM antenna is part of the lightning/headphone port with the connection just below the battery connector on the board i could be wrong I'm hoping someone will point me in the right direction if i am?
I'm suspecting the issue is down to the lightning port cable as it also has the speaker issue too.
What are your thoughts guys any help or suggestions would be greatly appreciated.
Thank you
Esta é uma boa pergunta?
Pontuação 1
1 comentário:
I agree with Justin, test a new port.
por
Adicionar um comentário
1 resposta
It seems to me you're on the right track. Seeing as though you have speaker issues, the lightning port could be on its way out. I would try switching that out first to see if you have better luck with the cellular connection, as well as the loud speaker.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Kenny Leonard será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 18
Ao todo: 201
