Ir para o conteúdo principal
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
208 Perguntas Visualizar todos
Upgrading 802.11n to 802.11ac
The Apple developers forum confirms that the new Auto Unlock with Apple Watch feature offered in MacOS Sierra works only with an 802.11ac, not with an 802.11n.
So if you want this feature to work, you will have to replace your <2012 n with an ac board.
The question then is the part number that corresponds to the 802.11ac that works in a <2012 MBM.
Update (01/22/2017)
Yes. Mac Mini.( And some more characters to meet the minimum requirement.)
Esta é uma boa pergunta?
Pontuação 4
4 comentários
What is your exact system here and model. Your TLA MBM doesn't make sense. MacBook Mini??
por
Bumping this as Dan is %100 right, you'll need to find the model number.
If you don't know how, use this: https://support.apple.com/en-nz/HT201894
If you post the Model number we'll be able to tell you if your MbM supports an upgraded WiFi card and what one you can upgrade it with.
por
Hi, I am looking at upgrading my wireless to ac also. I have validated my serial number via the link above and it confirms that I have a late 2012 Mac Mini. Can you please let me know the relevant part number for an ac wireless board?
por
Have either of you had any luck or figure out another solution? Thanks!
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Sadly the Airport boards are very different between the 2012 and 2014 models:
2012 board
2014 board
There is no upgrade option available. For a short time Broadcom offered some engineering samples which some people were able to get (long since gone).
Broadcom never offered a production part as Apple went with the mini-PCI interface board in the 2014 model.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Joseph Lough será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 4,618
