Ir para o conteúdo principal
O Xbox original é o primeiro sistema de videogame amplamente popular da Microsoft. Ele tem uma carcaça preta facilmente identificável com a inscrição 'XBOX' na parte superior e frontal. O reparo é fácil com ferramentas comuns.
Red Light issue .
Dear
The basic problem I am facing is that when I turns on my Xbox 360 ( yr 2011) It shows a red light on power button just like the green light at all corners and just after it switches off
Red Flashing type
Please help me out
Thanks
Esta é uma boa pergunta?
Pontuação 2
3 comentários:
is it red and green? or just red?
por Compartilhar
When it open its green and then it goes to red and then off
por Compartilhar
My Original Xbox is Flashing red-green..
The problems started a few months ago, when changing region to play 720p and 1080p games, everytime i starting the console it reboot endless times and not enter unleashx, i've to press a special sequence to enter unleashX safe mode, and load games etc..
last week i'm in good mod to understand the issues and resolve the problems, and have reseted the configs in unleashx and i see that some settings dont save after a complete power cycle, like default resolution, image soften filters, etc.
I've inspected the board and cables and everythings looks ok, without any capacitors leaking or white marks of older leaking componentes, and that said i've put back all toghether and leavit for another day.
yesterday, just simply power on and it's shows Error 12, and flashing red-green. I've tried another IDE cable same issue, the DVD drive dont read any disc right now(and is working a few months ago)..
Any help?
por Compartilhar
Adicionar um comentário
1 resposta
Solid red, overheated.
Flashing green, bad bios load.
Flashing red-orange, bad video output.
Flashing orange-green, AV cable not plugged in properly.
Flashing red-green, system faliure (can be alot of things).
well Heres A basic Breakdown on the indicator lights hope it helps..
a lot of times i have seen this issue and been able to fix by disassembling
cleaning and reassembling so I would try that first.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Abdullah será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 23
Ao todo: 3,188
