Ir para o conteúdo principal
Tablet de 0,622 kg com tela de 10,8 polegadas e suporte de 3 posições lançado pela Microsoft em 5 de maio de 2015. Número do modelo: 1645.
LCD Connector is damaged, help!
Hey all,
The connector where the LCD plugs in on my surface 3 was damaged during a screen replacement. The issue is I dont know what the part is called or where to purchase a new one.
Please help me
Update (10/06/2016)
Imagem
This is the connector in question. This is on the main logic board and the LCD flex plugs into it. The black piece that clamps down on the flex is gone and there is a missing pin.
Esta é uma boa pergunta?
Pontuação 0
4 comentários
Is it on the LCD or the logic board?
por
The connector on the board was damaged in case that wasnt clear.
por
[image|907316]
por
Mike check the update. Looks to be a internal 35 pin logic board LCD connector.
por
Adicionar um comentário
4 respostas
Solução escolhida
Mike, if you can post a picture of damaged connector, it would be a big help to ifixit , I believe the connector is the mother board ribbon connector. Check the attached link and see if it is the motherboard connector, Good luck.
Substituição da tela do Microsoft Surface 3
Update (10/06/2016)
Mike, Looks to be a internal 35 pin logic board LCD connector. Hope the link is what you want, you can also try a search yourself for (35 pin lcd connector)
https://www.aliexpress.com/item-img/20-P...
Esta resposta foi útil?
Pontuação 1
1 comentário:
Posted a picture below showing the connector.
por
Imagem
Imagem
Mine too damaged, are you sure it's 35 pin connector at AliExpress
Pontuação 0
I don’t think the above connector from Aliexpress is correct. Looking into it it seems to use the same connector that is on the Samsung Galaxy Note 4 2014. It is actually a 70 pin connector not 35 because there are pins on both sides. You might be able to buy a replacement off eBay or Aliexpress.
Below is the link to the connector on Aliexpress.
FPC Connector From Aliexpress
Pontuação 0
Did anyone ever get anywhere with this??
Pontuação 0
Adicionar a sua resposta
Mike Smith será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 20
Ao todo: 2,468
