Ir para o conteúdo principal
O Leader Impression i10A-LE é equipado com Android e entrou no mercado de tablets com um preço inicial de 299$ em 2012. As especificações incluem o Flash player integrado, resolução de 1024x768 e slot Micro SD que suporta até 32 GB.
Why do my apps keep crashing?
The internal memory of you device could be getting full. Try to go into your memory and delete some things to make room for the tablet to run more efficiently.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Your Apps could be crashing for multiple reasons.
Try to delete some internal memory in the device to make it easier for the app to run more efficiently.The more internal space the app has to run the less issues the app will have when in use.
If that doesn't work, try to delete some internal memory in the device to make it easier for the app to run more efficiently.The more internal space the app has to run the less issues the app will have when in use.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
riley seyffert será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 17
Ao todo: 407
