Ir para o conteúdo principal
Repair guides and support for the laptop/tablet hybrid in the Toshiba Satellite Radius series released in 2014.
Should I replace my battery?
So my comp will turn on if the charging cord is in and will say 100 % but if i take it out it turns off, and i can't turn it on without the cord. should i replace the battery?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi, As there are many variants in the P55W range, how long have you had the laptop? If it is less than 1 year, it is still covered by the manufacturer's warranty. If it is only just over a year old I suggest that you still contact Toshiba and voice you concern regarding the problem saying that you have always maintained it correctly etc. Here is a link to an Ifixit question where some of the symptoms are close to what you are experiencing. You may wish to look at it before you decide on the battery, as replacements are not cheap. Fully charged, won't turn on anymore
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
bob123 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 257
