Why does my phone only work when its charging
it starts up and then goes off repeatedly.
Esta é uma boa pergunta?
Hi,
If your phone only works when connected to the charger, most probably the battery is failing to hold its' charge and will need to be replaced. Even rechargeable batteries have a life span.
Here is the Ifixit guide on how to replace the battery.
Samsung Galaxy S5 Active Battery Replacement
Here is a link to just one supplier of the battery. If this supplier doesn't suit you there are others, just go online and search for Samsung Galaxy S5 Active battery.
Esta resposta foi útil?
Hi @ Paul Huntet,
Try the following to check if it resolves the problem.
a) Clear the phone’s cache partition. Here’s a link that shows how to do this. Check if the problems are still there or not.
b) Try starting the phone in safe mode and check if the problems are still there or not.
If they’re not then a downloaded app is the cause of the problem.
The trick is to find out which one.
You will need to uninstall each downloaded app one by one and then test the phone in normal mode between each uninstall to see if the problem is still there or not.
When it is no longer there then the last downloaded app that was uninstalled was the culprit.
Últimas 24 horas: 11
Últimos 7 dias: 139
Últimos 30 dias: 659
Duração total: 31,633
5 comentários
The battery works fine bolds charge the phone keeps ddoing randomly scrolls crap or reo0ens last aapp like fb to spotify lasts a m8n turns off
por Paul Huntet
How can I do in vivo
por Saw Na
Please please
por Saw Na
@Saw Na
What is the full model number of the BLU Vivo phone?
por jayeff
Mine too. Mine is Vivo 1919
por Emiry Yu
