Ir para o conteúdo principal
Model A1213 / 8, 16, or 32 GB capacity
216 Perguntas Visualizar todos
Pergunta encerrada
cant find repair guide on site
can you link this to me - i think it is either a dead battery or a bad board - it seems to be stuck in recovery mode if linked to itunes - other than that it will not even turn on....
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Can it hold a charge?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Here is a troubleshooting guide, and here are the repair guides!
Esta resposta foi útil?
Pontuação 1
Try holding down the home button while plugging it in this will bring it into DFU mode not Recovery and you might be able to restore. I doubt this problem is harware related as I have seen this problem solved many times by software means.
G'luck
Liam Speirs
Pontuação 0
1 comentário:
Except of course for the fact that it won't turn on...
por
Ok so i did what u told me to do and that was to hold the home button and is said the same thing. it said ipod in recovery mode must restore then i tried restoring it and it said unknown problem occcured . do u have any suggestions.
Pontuação 0
1 comentário:
Yeah, what liam speirs suggested probably would have done nothing, follow Ben Eisenman's advice.
por
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 2
Duração total: 1,046
