Ir para o conteúdo principal
An upgrade of the Nintendo Game Boy Advance, the Advance SP was released, in North America, on March 23 2004 with a square structure and clam-shell design.
20 Perguntas Visualizar todos
Why my game boy not charging?
So I had this game boy for along time but the ac adapter broke and after a lot of years a bought a new one but now the console is not charging at all... not even the red light goes on when I put the charger but the console still goes on and since the battery is dead it goes off right next
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Pergunta mais útil
First of all, check the current output of the charger. If that value is equal or above the one on the original, then the battery is dead and you should get a new one.
Esta resposta foi útil?
Pontuação 2
3 comentários:
Where can I get a new GBA SP battery? Does Nintendo still manufacture them?
por
A place where you will surely find one is ebay. Or Aliexpress. Sorry for the late reply.
por
Just a quick note, all batteries on eBay are probably not up to full capacity, so they won't last as long as a brand new one. Just pointing that out.
por
I would recommend getting a new battery as Ciprian R said above. If that doesn't work than it might be the actual connecter on the GameBoy. Take a quick peek inside it to see if there are any bent pins or any loose wires or such.
Pontuação 0
Adicionar a sua resposta
arthurpotterkarate será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 14
Últimos 30 dias: 15
Duração total: 5,110
