Ir para o conteúdo principal
I Have a vertical black line on my screen
Samsung Plasma... PS50A750T1FXRD Version SY01
I have a vertical black line on my tv screen that appeared from no where. I have tried unplugging my tv over night but this has not worked.
Any suggestions to fix this problem please..
Thanks
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
@newplymouth "a vertical black line" a single pixel wide and running all the way from top to bottom can be caused a bad PDP panel (Driver IC) NG or errors on the D board, or more common C board. You will have to take a closer look at your boards.
Esta resposta foi útil?
Pontuação 2
Pergunta mais útil
Warren, Samsung plasma,vertical black line on my screen. Check the attached links, hope they help in diagnosing your issue.
http://techin.oureverydaylife.com/causes...
http://www.justanswer.com/tv-repair/7160...
http://www.samsung.com/ca/support/skp/fa...
https://www.avforums.com/threads/samsung...
Pontuação 2
These may either be burnt or stuck pixels.
There are many methods of removing stuck pixels on the internet. Choose the one that best suits your purposes (ie using a program, repeatedly playing a video, etc)
Pontuação 0
Adicionar a sua resposta
Warren Powell será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 24
Duração total: 28,235
