High pitch squeal noise wile doing cycle
Does any one now what causes a high pitch squeal noise when a LG dishwasher is running its cycle? It is very frustrating and I need to fix it but don't know what is causing it. I thought that there was just some dirt in the pump so I flushed it out and ran a empty load with just water and vinegar to clean it out and it still does it.
Esta é uma boa pergunta?
6 comentários
Hi, Does it happen during the 'filling' action, the 'washing' action or the 'draining' action.
Filling could be sound of water through the inlet valve, washing could be the pump and not sure with your model but draining could be the drain pump. Some brands/models have two pumps - washing and draining.
por jayeff
Mine is only a month old, told that it needs to be broken in and recirculation pump noise will go away?
por Michael Lewis
Mine will be one year… it started from the beginning… guessing I need to call for service
por markjcoia
I had the same problem . Then I noticed it didn’t make the high pitched sound, when I ran it empty, while cleaning . After weeks of testing I determined that moving the dish, on bottom rack, inward by one slot, away from left wall made the noise disappear There is a jet or something, in the wall on the left side that the dish interferes
por Ronald
I have always used the cascade platinum in my dishwasher. We have had it for four years and over the last year it has been doing this whistling sound through several stages. It is very annoying. I wish I could find a reason why it is doing what it is. Any solutions other than noted?
por Teresa Wilson
Exibir mais 1 comentário
