Prints and Copies are coming out with jagged lines/texts
My prints and copies are coming out with jagged lines/texts
Esta é uma boa pergunta?
Hi,
Perform a print alignment check of your printer.
Here is an image that shows what to do.
Esta resposta foi útil?
You should run the cleaning cycle a few times I had an issue that there was lines and magenta wasn’t coming out the print head is just clogged
I ran the cleaning cycle several times and it didn't help. Does the printer head need to be changed?
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 24
Ao todo: 4,840
3 comentários
Thanks for your response Jayeff. However, I did try this several times but it made no difference.
por Khemchand Ramcharan
Re-aligning print heads doesn't solve the problem....
por Tracy Lloyd
Hi @ Tracy Lloyd,
Try cleaning the paper transport rollers in case they are causing the paper to stick and not feed through smoothly
por jayeff
