Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
623 Perguntas Visualizar todos
solid-state drive replacement in mac air 13" early 2015
I am currently having trouble with booting my machine due to the fact I have lost my firmware password. When I try to boot the icon padlock appears. I am currently in El Capitan OS and first noticed the problem when I upgraded from Yosemite to El Capitan.
Can I replace the solid-state drive safely? I would appreciate any help you can supply. Model Identifier-Macbook Air 7,2 Processor Name-Intel Core i5
Processor Speed- 1.6 GHz Number of Processors-1
Total Number of Cores-2 L2 Cache (per Core)- 256 KB
L3 Cache- 3 MB Memory- 4GB
Boot ROM Version: MBA71.0166.B12 SMC Version (system) 2.27f2
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Well, you're between a rock and a hard place here. Yes, you can replace your SSD but that won't disable the hardware password. But! If you only enabled drive encryption then replacing the SSD will resolve the issue.
Here's the IFIXIT guide to replace the SSD: MacBook Air 13" Early 2015 SSD Replacement as to the SSD its self you could go with an original Apple SSD but they are quite expensive. Instead I would recommend going with OWC unit: MacBook Air 11" & 13" Mid 2013, 2014, and 2015 SSD upgrades
If you need to reset your hardware password you'll need to visit an Apple Store with your original sales slip in hand.
Esta resposta foi útil?
Pontuação 2
1 comentário:
Thank you so much for your help, the info was right on point.
por
Adicionar a sua resposta
abdellahhassen será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 584
