Ir para o conteúdo principal
Guias de reparo, manuais e ajuda na resolução de problemas para Samsung Galaxy Tab sm-t113nu. Aqui você recebe tudo o que precisa para consertar por conta própria o seu Samsung Galaxy Tab sm-t113nu.
Dock mode clock problem
I have my tab docked and connected to the charger. While docked it shows the time and date. It also shows the weather. The problem is on the clock. For some reason the letter "K" is locked in the hour position no matter what time of day it is. The minute(s) position is working normally as is the temperature. Any ideas?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Hi, What Daydream app are you using to show the time/weather?
por
I'm so sorry, but I don't know how to figure that out. I believe it is stock. I don't remember downloading an app for it.
por
Adicionar um comentário
2 respostas
Solução escolhida
Hi @ohbroncofan
Here are two links that show how to check the settings for the Daydream feature.
If you are using an app to enhance the feature, it will have inserted more options than the standard options offered by Samsung.
http://www.samsung.com/us/support/answer...
http://www.howtogeek.com/170990/5-cool-u...
Esta resposta foi útil?
Pontuação 2
try using a diffrent app that others have used and that has good reveiws,
from a tech person,
@trustybacon, or bacon
Pontuação 0
Adicionar a sua resposta
Rob será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 16
Ao todo: 335
