Ir para o conteúdo principal
24" display; Built-in iSight Camera, Microphone, and Speakers; 1920x1200 resolution. Released October 2008, identified by model number A1267.
Screen flickers and goes black except when minimum brightness is set
I love my 24" LED Cinema Display and it has been working great until a couple of months ago. I started noticed that it didn't turn on after sleep but I finally found that it started working again if I dimmed the screen a notch. That problem sort of increased and now it's only working when it's set to the minimum brightness. If I increase the brightness it starts to flicker and then after a couple of seconds it goes black.
Everything else works as expected (USB, Camera, Charger etc).
Anyone with and idea on how I can fix this?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
The backlight it most likely dead. Set the brightness to the maximum, then when it goes black, point a flashlight at the display and see if you can detect a picture. If so, the backlight is almost completely out the window and can only deliver a very little amount of light. A quick Google search comes back with many useful results here.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jon será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 3
Ao todo: 405
