Ir para o conteúdo principal
Modelo A1103 / processador G4 de 1,25, 1,33, 1,42 ou 1,5 GHz
Word and Excel need virtual memory turned on.
I have OS X 10.3.9 and classic 9.2.2 installed on my mac mini power pc. When I open word or excel I am prompted, Word cannot load the Microsoft office 98 shared libraries. In the memory control panel make sure virtual memory is turned on.
When I open the classic system profiler I see virtual memory is turned off, is there a way to turn it on. Will this solve the problem and get Office 98 working again?
Sandy
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
3 respostas
Solução escolhida
In system 9 go to your Controls Panel, under the Apple in the upper left hand corner - Memory and turn it on. You can also expand the amount of memory allocated to an application by clicking on the apps icon once and go under File to Get info and raise the preferred memory.
Esta resposta foi útil?
Pontuação 3
1 comentário:
You may work with word files by using of word fix
Pontuação 0
Work with word files owing to xlsm repair tool
Read http://www.xlsmrepair.xlsrepairtoolbox.c...
Pontuação 0
Adicionar a sua resposta
Sandy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 2,563
