Ir para o conteúdo principal
Why is my wifi signal very week?
I put in a glowing apple logo in my iPhone 6 and broke my lock ribben cable and some where along the way I weekined my wifi signal I want to know the place of the connector to mak sure that it's not loose.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
I don't fully understand how you damaged your power flex but it sounds like you also managed to knock some parts loose on the antenna. Here is a picture of how the antenna system should look. My guess is you took off one of the pieces or knocked it loose: https://d3nevzfk7ii3be.cloudfront.net/ig...
For a glow mod, all you do is disconnect the battery, remove the screen, remove the battery and stick the thing on. You should have been near any of that stuff.
Esta resposta foi útil?
Pontuação 2
4 comentários:
I do know how I ripped the lock cable my screw driver slipped and tore part of it. And thank you I'm about to see what if anything is moved or missing in my phone
por
I realized that one of the screws is missing but from the center of the panel that you take of to remove the screen. Think this could be causing this?
por
Well I once had the same problem but I had to get a new phone just because of that!! Myb parents made me get a new phone!
por
I do have a spare 4 I don't care that much about do u think I could salvage a screw that would fit for the old 4 that would fit the center screw hole on the screen panel on my 6?
por
Adicionar a sua resposta
Evan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 77
