Ir para o conteúdo principal
Brother MFC-J825DW Printer "Unable to Init AF" Error Code
Read suggestions from Brother re. paper jams. No paper jammed - it prints fine. The issue is w/ the scanning/copying.
The bar(?) that glows green and travels under the glass gets stuck. You can hear it stuttering. Mind you, it does this as soon as it's turned on. I think it's part of its start-up process. I haven't scanned/copied anything since April taxes. Frustrating that something I rarely use all of a sudden causes problems.
Brother customer service was no help. Out of warranty. Woman was reading the page I had up in front of me, online. I certainly don't want to pay to have someone fix it as it will probably cost more than I paid for it new. I have a screwdriver - can anyone point me in the right direction? Thx.
Esta é uma boa pergunta?
Pontuação 1
5 comentários
Hi,
Just wondering, have you tried the ADF (auto document feeder) option to see if that scans/copies OK or does that fail as well as the scanner glass option?
por
When I "x" out the error code, the printer automatically tries to move the scanner "bar" again, makes noise, then the error code comes up again. Pressing the Photo, Copy, or Scan buttons don't register.
Also, trying to bypass the printer buttons by using the software to scan doesn't get me anywhere. If the error msg. on the printer is showing, the software gives me an error msg. if I try to scan something. If I clear it, it's only gone until it tries to move the bar again and then gets stuck.
And, no, trying to use the auto feed to scan or copy does nothing b/c I can't get the other printer buttons to work - as it's stuck/defaulted to Fax w/ the error code.
por
fehler:Init.f0 please inform me how i solved my BROTHER MFC-J5910DW PROBLEM?
por
HI.
Please inform me i have my Brothrt MFC -J5910DW HE HAVE PROBLEM( fehler:Init.f0)
Please help he how i can solved ?I cant print any documents?
Thanks
Syed
por
Couldn’t fix it. Bought a new printer.
por
Adicionar um comentário
5 respostas
Solução escolhida
Hi,
Here is a link, which describes what to do in the event of an "unable to ..." message being displayed on a Brother printer.
As you have already checked for any loose /stuck paper and foreign objects in the printer perhaps "Cleaning the encoder strip" as per Section B (scroll to about halfway down the page) in the link may be of some help.
http://support.brother.com/g/b/faqend.as...
If you have already been here, apologies.
Esta resposta foi útil?
Pontuação 2
1 comentário:
I found it useless since the problem was with the scanner head being jammed or losing it´s location and the link leads to info about the print cartridge head problems which has nothing to do with the scanner problem, The problem was with the scanner not the printer
por
My scanner bar started stuttering and getting stuck. The easiest way to repair this would be to replace the scanner assembly, as taking the scanner assembly apart does not appear to be covered by the repair manual.
I was able to take the thing apart, take apart the scanner, reseat things, and put it back together, and now the scanner works without getting stuck or making noise. HOWEVER there is probably A LOT of potential for messing this procedure up, and there are parts that are very finicky.
So if you want to try to fix this, the first thing you're going to need is this file -- the service manual: http://support.brother-usa.com/Virdata/C... SM_MFC_J280W_J425W_J430w_J435W.pdf
Follow the instructions from page 3-49 (PDF page 186) through 3-53 (190 in the PDF). Now you should have your scanner unit detached from the rest of the printer. And now you enter no man's land - the manual doesn't seem to help with the rest.
Basically next I took out all the screws I could see. After that, I was able to get the glass to separate from the lower part of the scanner. Under the glass is the scanner bar, the motor that drives the belt that moves the bar, and TWO WEIRD WHEELY THINGS. In my case, I think one of the wheely things was out of place and causing problems. To get the wheely things in place, turn the scanner assembly right side up and look at the top and bottom of the bar. The wheely things are shaped slightly differently and will only mate with one end of the bar each. Before putting them on, move the bar all the way to the left and make sure the cable at the top that follows under it and gets pushed back when the scanner returns to it's home position is smooth and not kinked if you can. Then place the wheely things in position and CAREFULLY replace the glass, ensuring that the wheely things don't move out of place. After this, put all those screws you took out after departing from the manual back in ASAP so that the wheely things lock in place. Now, put the thing back together and pray to your favorite deity. In my case, this worked out.
Worst-case Ontario, you'll just have to replace the scanner assembly (basically the entire upper portion of the printer that is hinged).
Good luck. You'll need it.
Pontuação 2
Probably it is not detecting the White Tape on the inside of the scanner unit. It is this that the scanner uses to know when it is in its home position.
The Service manual has a section on that
The AF error indicates that it is not detecting the white tape at its home position
Acquisition of White Level Data
Function Code 55
You will need to enter the end user maintenance mode for your machine.
https://www.printertec.com.br/arquivos_d...
This is my model machine but the procedure is the same
Hope this is of help to you. You may not need to use the screwdriver at all.
David
Pontuação 1
I know that the OP has long since moved on from this problem, but I just dealt with an "Unable to init.AF" error myself, and here's what the cause was in my case:
I had stored the printer for a significant amount of time in its box, sitting on its side. I did not take the ink cartridges out when I put it away, and in storage, ink leaked and seeped all over in the printer. One place the ink found its way to was the white tape for light bar orientation that David mentioned above. It had wicked in between the glass and the plastic frame, and completely obscured one of the white bars, thus the light bar couldn't detect its "home" position, and would hit the end of the track and keep pushing, causing the belt to skip as the OP described.
For me, the solution was to remove the scanner glass and clean the ink from the white tape bar, clean the glass, and reassemble.
Pontuação 1
1 comentário:
This was my problem as well. The white tape bar was completely shaded blue by the ink that had spilled out. The scanner bar could not find the "home" position as a result of the white bar being covered completely in blue ink.
por
Mine was a folded in the data ribbon, on right hand side under scanner bed assembly . Check you data ribbon for folds or kinks. It was my quick reassembly that caused it. be very careful with the data ribbons (black flat cable).
Pontuação 0
1 comentário:
I appreciate the suggestion - alas, that printer is long gone… Couldn’t fix it. Maybe your info. will help the next person. Thx.
por
Adicionar a sua resposta
Desertboot será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 54
Duração total: 24,331
