Ir para o conteúdo principal
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
66 Perguntas Visualizar todos
What type of starter does it have and where?
The mover starts very erratic, it may turns over or not or just a 1/2 turn. Voltage drops to 6v .
Esta pergunta é pertinente?
Pontuação 1
Adicionar um comentário
1 Resposta
Pergunta Mais Útil
@hwggiese the ZTS comes with either a Kohler or a Briggs and Stratton engine. So you will have to give us more details on that. On both types the starter is held to the engine with 2 bolts that are near the top of the starter. Remove those 2 screws on the starter and then remove the nut that secures the power wire to the starter then remove the starter. On some engines there will be a little cover over the top of the starter that must be removed in order to access the starter bolts. So we need more info to point the starter out to you
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Henry Giese será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 7
Últimos 30 dias: 18
Duração total: 592
