Ir para o conteúdo principal
Released on October 23, 2012. Core i5 or Core i7 Processor. Apple Fusion Drive.
200 Perguntas Visualizar todos
How to upgrade Mac Mini Server late 2012 Macintosh HD2 to 5TB?
The MMS late 2012 has a Server HD and a 1 TB Macintosh HD2 nearly full occupied by photos. I wonder if it's feasible to upgrade the 1TB Macintosh HD2 to a 5 TB hard drive and how?
Esta pergunta é pertinente?
Pontuação 3
1 dos comentários
This question was migrated from http://meta.ifixit.com/Answers.
por
Adicionar um comentário
1 Resposta
Solução escolhida
Sorry the Mini's use 2.5" drives so you're limited here on what available in this form factor. So far there are no traditional HD's that large that would fit.
So far the best you can do with traditional drives is 2 TB. I have a dual Spinpoint 2TB HD (4 TB total) Mini as my media server.
Now if you want to go bigger you'll need to go with SSD's using two Samsung 4 TB SSD drives which would get you 8 TB total!
But it will cost you big time!!
Esta resposta foi útil?
Pontuação 0
3 comentários:
I should also point out you can even go larger, hows 16 TB sound! If you can find enough loose change ;-}
Samsung Releases 16TB SSD That Only The Wealthy Can Buy. And this is whats coming: Samsung crams 32TB SSD into a 2.5-inch drive, aims for 100TB by 2020. Enjoy!
por
Thank you Dan. I'm happy to go for 2TB. How do I know which HDDs are compatible on MMS and macOS Sierra? At reasonable price and available with warranty?
por
Not sure I follow you here with your comment on MMS. You'll need a Mac compatible app to do that the drive has nothing to do with it.
As for macOS Sierra this Mac mini is on the supported listing so thats not an issue, and again the HD has nothing to do with it either as its just a standard SATA drive.
Click on the blue URL link I posted above it's the only drive that will physically fit as the height of the drive can't be any higher as there is not enough space for a bigger drive can some larger drives have.
por
Adicionar a sua resposta
Ivan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 1,182
