Ir para o conteúdo principal
Xbox One Kinect. Incluído com o Xbox One. Ele vendeu com sucesso mais de 23 milhões de unidades em todo o mundo.
Replacement cable for Xbox One Kinect
Is it possible to buy a replacement cable for the xbox one kinect? Just the cable? I can't find one anywhere online.
Thanks to everyone!
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
If you mean adapter there is only usb to Kinect port which can be used for Kinect in order to connect it with XBOX ONE S which does not have Kinect port. If your Kinect has any problem with it's cable you can remove it and replace it but only on ebay I have found (xbox one kinect cable) that's how I search it because there are power cables for kinect for xbox 360
Esta resposta foi útil?
Pontuação 0
Not sure if this can help you, but the cable is a USB 3.0 cable with two additional pins, I assume for additional power. The ‘B’ end of the cable attaching to the sensor accomodates a standard USB 3.0 ‘B’ connector directly, but leaves the two additional pins on either side of it unconnected. The ‘A’ end of the cable is obviously, then, also non-standard, but in this case it is not physically compatible with a standard USB-A port.
read: assumptions
If you need the adapter cable for a newer Xbox or for PC (I believe they are one in the same) search for that specifically, as there is no other solution as far as I am aware.
If you need to repair the proprietary cable attached to the sensor itself, then I would search ebay’s damaged device auctions. (or be adventerous with a custom solution using the info above, if willing :D)
Pontuação 0
Adicionar a sua resposta
Lencar será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 16
Ao todo: 1,620
