Ir para o conteúdo principal
Repair guides and support for riding lawn tractors sold under the Murray brand name, currently owned by Briggs & Stratton.
20 Perguntas Visualizar todos
When was this mower made Murray model # 40702x92c?
When was a Murray riding lawn mower made, Model # 40702x92c
It has a tag under the above model # that says date of manuf. 3063.
It must be coded #. I know its not made in 1963.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
3 respostas
Solução escolhida
bobthomas1944 you are probably right when you say that it was not build in 1963. But it could have been build the 63 day of 1973.
Murray used a couple different ways of how the date of manufacture was list.
1970's tag format YDDD
1980 and early 1990 tag format DDDY
Late 1990 and Early 2000 tag format YYDDD
Early 2000 on MM/DD/YYYY
Your model number 40702x92c tells us that it has a 40 inch deck was, actual model is 702 and was build for X92C which could be anyone from Walmart to homedepot. Basically it is who it was build for.
You may have better luck by checking the tag or stamping on the engine. Let us know what you find.
Esta resposta foi útil?
Pontuação 3
I believe it is a julian date. So 3063 is 2003 (the first digit is the year) and 063, the 63rd day of 2003 would be March 4th
Pontuação 0
2 comentários:
So then if mine says 2733 when was mine built
por
Depending on the formate of which your model number is written it’s gunna be the 273rd day of either 1983 or 1993. If the model number format is ( x-xxxxx) it’s a 1983 year ..but If the format is (xxxxxxxx)….a number without a “dash” being used in it…then you have a 1993 year
por
40508x92d what year was made mf date01253
Pontuação 0
1 comentário:
The 5 digit format for the manufactured date was used from the late 90’s to the early 2000’s. So yours was made on the 253rd day of 2001.
por
Adicionar a sua resposta
bobthomas1944 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 6,999
