Ir para o conteúdo principal
Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
lcd repair gone wrong
i tried to replace iphone 3g lcd screen and now it will not turn on. i followed the video and now it does not respond when i turn it on
Esta é uma boa pergunta?
Pontuação -1
Adicionar um comentário
2 respostas
Pergunta mais útil
also try plugging it into the wall and doing the reset.
Esta resposta foi útil?
Pontuação 1
1 comentário:
+ fixes lots of problems.
por
also, you could try (assuming it's powered off) connecting it to itunes. this way it should power on even if the power button cable is damaged (but of course leaves you with the problem of switching it off again). after plugging in, wait a minute and see if itunes recognizes it. that would mean the problem is the lcd.
Pontuação 1
1 comentário:
+good point, or toggle mute on & off
por
Adicionar a sua resposta
Jessica Humeniuk será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Ao todo: 1,301
