Why my acer laptop wireless internet is not working?
i have a acer laptop but all of the suddan my acer laptop wireless internet is not working but all other devices are connected with router at my home . please help
Esta é uma boa pergunta?
just reset the settings in wireless adaptor . and make sure you update the wireless driver after reset and see if any other program is not blocking the internet connection . check the wireless adaptor settings for any other help before you try reset the computer just visit acer for latest driver and manual click http://www.acer.com/ac/en/US/content/sup... and let me know if you need any other help
Esta resposta foi útil?
got it fixed . thanks
Hi good evening I just loaded to my swift now and am trying to connect it to my laptop but it's saying it can be connected please why I need for an exam now?
as far as i know this problem is coming with lot of windows 10 devices anyway - i did not liked windows 10 for many more reasons just follow the steps see if this helps you
reset the wireless adapter and remove the wireless driver and restart the computer after restart just go to wireless driver settings and uncheck the power management mark and update the driver see if that helps you . thanks
hello everyone ,
i had a acer laptop while ago and i had this problem once . please try thease steps and see if this works and solves the problem
1- try updating the wireless driver . push window key +R at same time and you will see run box at the left bottom side of computer type ncpa.cpl and click ok
2- Here you can select your wireless adapter and go to the properties of the adapter and select the driver of the adapter and go to the driver section now click on update the driver and it will update it .
3-try removing any filter from adapter and check the firewall setting
4- if these steps do not work follow FIX Windows computer wireless problems
and please comment below to let me know if it did fixed the issue . thanks
i tried almost everything but did not worked for me
thanks it helped the part after update . thanks
Thank you soooooo much! This was sooo helpful!
Tried but it didn't work our other laptop and phones connect but not this acer and a kindle
My wireless adapter stopped showing up in devices after update, its an acer aspire r11 but it came with windows ten
check the wireless driver and settings and update the wireless driver . thanks
i am also having the same issue . somehow its just not working . i don't know what should i do to solve this problem . should i just change the wireless card of my laptop . does that solve the problem
i just tried updating its still not responding and no wireless connection . now i can not see any network name or any network
how the f do you update drivers, my lovey, if you can't connect to the freaken internet!!
Guys,
Even I had the same problem. Got it fixed.
If all other methods failed, All you need to do is remove the battery from behind and reinsert the battery.
You are good to go.
To remove battery in Acer, just insert a pen into the hole behind and push it to the right.
The battery will pop out.
All the Best
VJ
Suffered this problem for a couple of years, got fed up and configured the internet for ethernet cable. Now each time the wireless card packs in, just plug in the ethernet connection and for some miraculous reason unbeknown to man, the wireless switches back on each and every time.
Finally!!!!!
i am also having the same issue . but i think reset the wireless settings and checking the driver status will help for more i thing uncheck the power managment option fron driver settings
thanks it worked for me
i tried reset and uncheck the power management from wireless adapter and its not working at all.
please try uninstalling and installing the wireless setting see if that works
hi i am having trouble when you log on to internet and log on again it wont hold information sent it away for repair they said it was screen problem when igot it back from repair still the same i amwaiting on answer from store where i bought it to see what they say any ideas
reset the wireless driver and uninstall it and than restart the computer and get the latest driver from acer site and make sure you check the playback device settings in sound manager
1. Go to device manager .... Check the drivers installed .
2. If drivers are installed properly ...and seemingly there are no other issues, then just remove your battery, disconnect from charger wait 10 -15 secs put back battery and check.
3. Still not ? may be your wi-fi internal card connectors got unpluged usually doesn't happen.
no i think you may need to reset the wireless adapter and wireless ettings and try updating the adopter again if nothing works than you might need to reset the computer
Where do I find the Local Area connection adapter to enable it
Hi,
If you have Win 10 installed, right click on the Windows Start button on the left side of the Taskbar and click on the Device Manager link.
When in Device Manager scroll down to Network Adapters and click on the > symbol to the left of Network Adapters to expand the list.
Then right click on the LAN network adapter entry and click on enable.
https://okadtech.com/acer-nitro-5-wifi-p...
Just go and solve your problem and thanks me later
Últimas 24 horas: 8
Últimos 7 dias: 35
Últimos 30 dias: 152
Duração total: 125,527
15 comentários
i would say check the wireless driver and update it http://goo.gl/GXXiB1 and make sure you have the right driver and settings
por joshgranada
thanks i was helpful and i got my wireless working . thanks you so much
por tom larry
try removing the check mark also from wireless adapter for power managment checkout the wireless adapter properties settings .
por Ethan Carter Carter
after doing everything its just still not working .
por armu
now its not showing any wi fi network
por roberthickman
Exibir mais 10 comentários
