Ir para o conteúdo principal
Lançado em março de 2006, identificado pelo modelo D620 no bisel do teclado.
Screen distorted and very fuzzy
Hello,
I just hit the jackpot at the Salvation Army and got an iBook, 2 dell latitudes and a hp pavilion. One of the dell latitudes work, but the screen is very fuzzy and distorted. This is probably a cold solder joint under the gpu or chipset, but other than that it works just fine. Is the gpu removable, or is it soldered on? Also, how would I fix it at home?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Never mind, just zapped the gpu with the heat gun on high for about 4 minutes and now it works fine.
Esta resposta foi útil?
Pontuação 2
Hiya,
When you say heat gun.... what sort of gun do you mean?
A small gas torch, a large one, or a cigarette lighter? . Does this really work?. I'm using a D620 with the Intel VGA card, and it's great, but I have two dead ( 1 fuzzy, one non boot ) with the defective VGA card from the other manufacturer where there was class action against DELL..
I'd lvoe to get them going although I have swapped the disks so I got all the data off ok.
Regards
Eddie
Pontuação 0
1 comentário:
I used the same heat gun that I fix it sells and heat it up. If you look up the Xbox 360 rrod fix kit it will show you how to reflow the chip.
por
Adicionar a sua resposta
Gigabit87898 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 23
Ao todo: 588
